180135: Column: <value> is a required column in sheet: <value>.
The tool encountered an error while validating required columns in the input Excel template file.
Solution
Verify that the input Excel template has a value in the column specified in the error. Confirm that the value is correct when you map floor plans to Indoors. Contact Esri technical support for more information.
