180159: <value> will be skipped. <value> is empty or does not exist.
No file was located at the path specified in the SOURCE_PATH column of the Level Properties sheet. The file name or path may be missing or incorrect.
Solution
In the configuration Excel file, confirm that the Level Properties sheet's SOURCE_PATH column contains the correct paths.
