180161: Level Properties sheet cannot have SOURCE_PATH column.
Starting at ArcGIS Pro 2.7, the input Excel template file includes a Source Files sheet. When the Source Files sheet is present, the SOURCE_PATH column must appear on the Source Files sheet and not on the Level Properties sheet.
Solution
Review the template file and ensure that the SOURCE_PATH column is on the Source Files sheet and not on the Level Properties sheet. Also confirm that the path and level information on the Source Files sheet is correct.
