180162: User has not defined <value> OPENINGS layers to import in CAD Layer to FC Mapping worksheet but has set the CLOSE_DOORS property to Y in the Level Properties worksheet. Skipping import of OPENINGS.
The CLOSE_DOORS column is set to Y on the Level Properties sheet, but the OPENINGS column is empty or contains the name of a CAD layer that could not be found in the CAD data referenced in the SOURCE_PATH column of the Source Files sheet.
Solution
Confirm that the values are correct in the OPENINGS column of the Layer to Feature Class sheet.
