180163: Units data was imported from UNITS layers mapped from CAD source files. Any values in the OPENINGS and CLOSE_DOORS columns were ignored.
Units data was imported from polygon data in the UNITS column of the Layer to Feature Class sheet. The Door Close Buffer parameter requires polyline data from the UNIT_LINES column. Any values in the OPENINGS and CLOSE_DOORS columns were ignored.
Solution
To use the Door Close Buffer parameter, list one or more CAD polyline layers in the UNIT_LINES column of the Layer to Feature Class sheet. Remove CAD layers from the UNITS column.
