180165: Invalid target field name: <value> in Annotation To Field worksheet. Skipping annotation mapping for the targeted field.
On the Annotation to Field sheet, the specified target field name is not valid. This warning can occur in the following situations:
The specified field does not exist in the target feature class.
The specified field is populated by the Import Floorplans To Indoors Geodatabase tool using data from other sheets in the Excel configuration file.
Solution
Confirm that the specified field exists in the target feature class.
If the specified field is populated by the tool, you can add a custom attribute field to the feature class and target the custom field when mapping the annotation. After the tool runs, you can copy values from the custom field to other fields as needed.
