180263: Field name <value> must have a Text type and <value> length.
The fields set for the Level ID Field or Use Type Field parameters do not match the required schema. The Level ID Field parameter value must have a text data type and a field length of 255. The Use Type Field parameter value must have a text data type and a field length of 50.
Solution
Ensure that the fields set for the Level ID Field and Use Type Field parameters match the required data type and field length.
