180305: Level value is null.
The tool encountered an error while identifying continuous transition spaces on adjacent floors within a facility.
Solution
If you are using an indoor dataset and preliminary indoor network dataset, confirm that the Units features are assigned correct LEVEL_ID field values and that PrelimPathways features are assigned correct VERTICAL_ORDER field values.
If you are using an Indoors geodatabase, confirm that the input facility features, transition unit features, and pathway features each include a VERTICAL_ORDER field and that the VERTICAL_ORDER field is populated with values for all features.
