180400: Invalid BIM file workspace.
The Input BIM File Workspace parameter value must be a .rvt file supported by ArcGIS Pro or the Floorplan_polygon layer from the source BIM file added from an active map.
Solution
Ensure that the .rvt file is supported by ArcGIS Pro. If the file was created using an older version of Autodesk Revit, you may need to upgrade it to the latest version.
