180425: Intersecting feature found in Facilities feature class with a different Facility ID or Name. Pass the same Facility ID and Name to update or check the Allow insert of new overlapping facility option.
The facility in the input BIM floor plan intersects an existing facility in the target indoor dataset.
Solution
Do one of the following:
If the input BIM floor plan is a new facility that you want to add to the target indoor dataset, check the Allow insert of new overlapping facility parameter and run the tool again. The tool will import the new facility, and existing facilities in the target indoor dataset will remain unchanged.
If the input BIM floor plan is an updated floor plan for an existing facility in the target indoor dataset, ensure that the specified Facility ID and Facility Name parameter values match the
FACILITY_IDandNAMEfield values for the Facilities feature you want to update, uncheck the Allow insert of new overlapping facility parameter, and run the tool again. The tool will update the existing facility.
