180553: Occupant table Identifier field must be set.
If you provide a value for the optional Input Occupant Table parameter, a value for the Occupant Identifier (Input Occupant Table) parameter is required.
Solution
Specify a field for the Occupant Identifier (Input Occupant Table) parameter that contains values that match values in the field you set for the Occupant Identifier (Target Occupant Features) parameter.
