180557: Cannot map source <value> to target <value>. Fields have different types.
The fields you map from the input occupants table to the input occupants features using the Occupant Attributes Mapping parameter must have the same data type.
Solution
Specify fields with the same data type when mapping fields using the Occupant Attributes Mapping parameter.
