180569: Invalid Occupant Attributes Mapping parameter value. Cannot map to field: <value> because it is set as the Occupant Identifier.
The field provided for the Occupant Identifier parameter is used to match information from the input Occupant table to the target Occupants layer and cannot be overwritten using field mapping in the Occupant Attributes Mapping parameter.
Solution
Remove the occupant identifier field from the field mapping in the Occupant Attributes Mapping parameter and run the tool again.
