180676: Input Floorplan layer is not valid.
Values for the Input Floorplan Footprint Layer, Input Floorplan Polygon Layer, and Input Floorplan Polyline Layer parameters must be feature classes or feature layers created using the Extract BIM File Floorplan tool on the same IFC file used for the Input BIM File Workspace parameter.
If the Load From Floorplan Layers parameter is checked, you must provide input floor plan layers for all input floorplan layer parameters.
Solution
Run the Extract BIM File Floorplan tool and use the output layers as input to this tool or uncheck the Load From Floorplan Layers parameter and rerun the tool.
