180681: Cannot map source field <value> to target field <value>. Target field <value> is not valid or does not exist.
The field set for the target field in the Unit Properties Mapping parameter is not a field in the Spaces category or cannot be mapped. The target field must exist in the target Units layer. This mapping will be skipped.
Solution
Ensure that fields exist in the target Units layer for all of the source fields you want to map from in the IFC file.
