180758: <Value> is not locally sourced.
The specified layer must be sourced from a file geodatabase or an enterprise geodatabase. Layers sourced from a service are not supported.
Solution
Copy or export the layer to a local (file or enterprise) geodatabase, and run the tool to use the local copy. Alternatively, create an empty feature class in a local geodatabase, run the tool using the empty feature class, and append the resulting features to the non-locally sourced layer.
