180759: Input data is positioned outside of the xy domain of the target oriented imagery.
The x- and y-coordinates of the extracted images are outside the acceptable range for the target oriented imagery dataset's coordinate system. This error may occur when the datasets specified for the Input Data and Target Oriented Imagery parameters use different coordinate systems and the Input Coordinate System parameter is not specified. This error may also occur when the specified input coordinate system is different than the input data's actual coordinate system.
Solution
Verify the coordinate system of the input data with the data provider. Set the Input Coordinate System parameter to the correct coordinate system for the input data.
