180763: No LEVEL_ID assigned to imported images.
The LEVEL_ID values could not be assigned to any of the imported images.
Solution
Check for the following possible causes:
The images are horizontally positioned outside of levels. Outdoor images are not assigned a
LEVEL_IDvalue. If this is unexpected, verify that the correct coordinate system was selected for the Input Coordinate System parameter.The images are vertically positioned outside of levels. If this is unexpected, verify that the correct vertical unit of measure is set for the input coordinate system. If the images and levels use different elevation origins, set the Elevation Adjustment parameter to accommodate.
The input Levels layer has no features, or the level features have no
LEVEL_IDvalues.
