180831: No data found to process.
No data was found in the point cloud that met the region specified by the processing parameters.
Solution
Verify the following:
The point cloud has data within the processing region defined by the Extent environment and the Z Ranges parameter.
The point cloud has no filters or constraints applied that would exclude the data from the defined processing region.
The coordinates in the point cloud are valid for the specified coordinate system. For example, if the Coordinate System parameter value is a geographic coordinate system and the coordinates in the point cloud are outside the acceptable range for a geographic coordinate system (-180 to 180 degrees longitude, -90 to 90 degrees latitude), this error occurs.
