180832: No data found to process in Z range '<value>'.
No data was found in the point cloud for the specified processing z-range when combined with other processing parameters. Data was found in other processing z-ranges and was processed.
Solution
This warning may be expected when specifying multiple processing z-ranges for a subset of the point cloud data as defined by the Extent environment, LAS filter, or surface constraints. If this warning is unexpected, verify the following:
The point cloud has data within the region defined by the Extent environment and Z Ranges parameter.
The point cloud has no filters or constraints applied that would exclude the data from the defined processing region.
