180835: Input processing extent is invalid.
The processing extent defined by the Extent and Z Ranges parameter values could not be used.
Solution
Verify the following:
The specified range's minimum z-value is greater than the largest z-value in the point cloud data, or the specified range's maximum z-value is less than the smallest z-value in the point cloud data.
The x,y coordinates specified for the Extent parameter include the area containing point cloud data.
