181002: The <value> field value is empty for one or more input Levels features, the <value> field value will be used instead.
The level's NAME_SHORT field value is used to populate the LEVEL_NAME_FROM and LEVEL_NAME_TO fields on the generated pathways. This value is used by the network dataset to generate step-by-step directions. If the NAME_SHORT field value is Null or empty for a level, the LEVEL_NUMBER field value will be used to populate these fields.
Solution
Do one of the following:
Populate the
NAME_SHORTfield value for levels in the Indoors workspace and run the tool again.Take no action. The
LEVEL_NUMBERfield value will be used in callouts when routes are generated using the final network dataset.
