181004: A facilities layer could not be found in the same workspace as input levels features. <Value> field will not be populated for generated pathways.
The tool populates the FACILITY_NAME field in the following ways for generated pathway features:
If the input levels are from a floor-aware map, the tool uses the layer set as the Facilities layer in the map properties.
If the input levels are not from a floor-aware map, the tool searches for a Facilities layer in the Indoors workspace where the Levels layer is sourced.
If no Facilities layer is found, the tool does not populate the FACILITY_NAME field in the generated pathway features. This field value is used when providing routable directions in the Indoors web and mobile apps.
Solution
Do one of the following:
Provide a Levels layer from a floor-aware map as input to the tool.
Provide a Levels layer from a workspace (geodatabase or feature service) that also contains a Facilities layer or feature class.
Update the
FACILITY_NAMEfield manually for generated pathway features.
