181009: Unable to generate transitions for facility <value>, at least two levels are required.
Two or more levels are required to successfully generate vertical floor transitions.
Solution
Do one of the following:
If the specified facility contains more than one level, ensure that multiple levels are selected in the input Levels layer to generate vertical floor transitions in the facility and run the tool again.
Do nothing. Only horizontal pathways will be created.
You can create floor transitions between levels with existing pathways later by running the tool with the Pathway Generation Method parameter set to Transitions Only.
