181101: Video frames lack expected 2:1 width to height ratio. Extracted images may not display as expected.
The file specified for the Input 360 Video parameter must be a 360-degree equirectangular video in which the pixel width (360° horizontal field of view) is exactly twice the pixel height (180° vertical field of view). A different aspect ratio indicates that the video may not be equirectangular or may not be a true 360-degree video.
Common causes for an invalid width-to-height ratio include the following:
  • The video was cropped, removing part of the original frame.
  • The video was captured or exported in a projection other than equirectangular.
  • The source is not a 360-degree video.
Solution
Do nothing. The tool will still attempt to process the video, but results may be incomplete, incorrectly positioned, or distorted. Images may also fail to display properly in 360-degree viewing tools. If visual issues persist, review the video file for potential issues.
