181110: Control point video times must be at least 5 seconds apart.
The tool estimates control point locations using video frames before and after each specified video time. If two control points are too close together in time, the surrounding frames can overlap, which may reduce the accuracy of the location estimates.
Solution
Adjust one of the Video Time parameter values so that the control point is at least five seconds from the other control point. Update the associated Camera Location parameter value if needed.
