181113: Video must be at least 15 seconds long.
The input video file or specified video segment did not have enough footage for processing. A minimum of 15 seconds of real-time video footage is required to assist with accuracy when deriving camera position and orientation information from the video.
Solution
Provide a video file that contains at least 15 seconds of video footage for processing. If setting the Start Timestamp or End Timestamp parameters, ensure those parameters specify a segment of video footage at least 15 seconds in length. When working with time-compressed video, make sure the Video Capture Type and Video Capture Rate parameters are set appropriately. For time-compressed video, the video playback length required will be shorter; for example, for a 2x speed video the required minimum playback length is reduced by half to 7.5 seconds.
