190237: Input Data: Dataset <value> does not exist or is not supported
The tool was unable to open your dataset.
There are two reasons that could prevent this tool from opening a particular dataset:
The tool could not find the data because the input data path was typed incorrectly or does not exist.
The data path is not a directory.
Solution
Check the data path used to make sure it exists, is a directory, and can be accessed by ArcGIS. Correct as required and run the tool again.
