230030: The Compensate for Sparse Categories option is not honored by the cross-validation.
The original classification model, from the Forest-based and Boosted Classification and Regression tool, had the Compensate for Sparse Categories parameter checked in that tool. The compensation setting is automatically inherited by the cross-validation models. If you modify the Balancing Type parameter value, the original model's compensation setting will not be honored in the cross-validation.
To use the original Compensate for Sparse Categories parameter value, set the Balancing Type parameter to the naive Random Undersampling option.
