240031: Unable to populate route type for stops.
The GTFS Stops To Features tool cannot determine the modes of public transit that use each stop from the route_type field in the GTFS routes.txt file. The JSON values in the route_info field in the output will not include the route_type key.
Solution
Review the other warning messages for the reason the route type cannot be determined and correct the problem. Alternatively, ignore the warning if you don't need the route_info field or the route_type key in that field's JSON values.
