250026: Recording with object id <value> does not contain enough survey points. The recording will not be processed for the positioning data.
One or more recordings in the IPS Recordings Features parameter value contain less than two survey points. A minimum of two survey points are required.
Solution
Delete recordings that contain fewer than two survey points from the IPS Recordings dataset.
