250050: Recording with object id <value> has more than one attachment file. The recording will not be processed for the positioning data.
One or more features in the IPS Recordings Features parameter value contain more than one attachment. Only one valid recording file attachment can be processed per feature.
Solution
Verify that the feature for the specified ID contains only one valid recording file attachment generated using the ArcGIS IPS Setup app. The name of an IPS recording file adheres to the following naming convention: XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX.pb.
