250059: Level features with the following Object IDs will be excluded from processing because of insufficient data: <value>.
To be processed in the survey-less method, a level must be associated with at least four beacons, one IPS area, and one wall feature. To be processed in the survey-based method, a level must be associated with at least one IPS recording.
Solution
If you generate the indoor positioning dataset using the survey-less method, ensure that at least four beacons, one IPS area feature, and one wall feature are associated with each of the levels for which the positioning data will be generated. If you generate the indoor positioning dataset using the survey-based method, ensure that at least one IPS recording is associated with each of the levels for which the positioning data will be generated. The LEVEL_ID value in the features must match the LEVEL_ID value in the levels.
