250099: A published Indoor Positioning Data Service containing the same IPS positioning dataset already exists on the portal: <value>.
The indoor positioning data service to be shared contains an IPS positioning dataset that has already been published. IPS positioning datasets must be unique within the portal.
Solution
To use the IPS positioning dataset you are about to share, use the existing indoor positioning data service provided in the error message.
