250104: Update of the Indoor Positioning Dataset failed.
The provided inputs cannot be used to update the selected indoor positioning dataset. The inputs must be located in the same areas that the selected indoor positioning dataset covers. In the case of a survey-based update, IPS recordings must have the same signal type.
Solution
Ensure that you use inputs that cover the location of the selected indoor positioning dataset. Additionally, to update the selected indoor positioning dataset with the survey-based method, provide IPS recordings of the same signal type.
