250109: Recording features with the following object IDs will be excluded from processing because they do not cover the same area as the existing IPS positioning points at the same level ID: <value>.
The recording features can't be used to update the existing IPS positioning points because they do not cover the same area at the same level ID.
Solution
When updating an indoor positioning dataset, ensure that the IPS recording features cover the same area as the existing IPS positioning points.
