250114: Beacon features with the following object IDs didn't produce any IPS positioning signals: <value>.
In the survey-based method, this warning appears if the IPS recording features do not contain radio signals from one or more IPS beacons. In the survey-less method, the warning appears if one or more IPS beacons are too far from the specified IPS area.
Solution
Review the list of IPS beacons that were excluded from processing. If these beacons should be part of the indoor positioning dataset, include IPS recordings from the areas where they are deployed, and verify that the beacons are operational. To generate a positioning dataset using the survey-less method, select beacon features that are not too far from the IPS area.
