250123: The value is outside the recommended optimal range from -82 through -75.
For typical indoor beacon deployments the recommended optimal range is from -82 through -75. That range gives the best trade-off between coverage, location accuracy, beacon density, radio frequency noise, and beacon battery life. Values outside this range can lead to suboptimal deployment results.
Solution
Update the RSSI at 1 meter (3.2 feet) parameter value to be within the recommended range to ensure effective coverage, reliable performance, and minimal impact on beacon battery life. You may also proceed without changes if the configured value has been verified as correct for your deployment.
