250126: The beacon placement plan was not generated for the floors with level IDs: <value>. The required signal coverage could not be achieved.
The tool was unable to generate a placement plan that meets the required signal coverage for one or more levels. This can occur when there are insufficient wall segments to support beacon placement, or when the IPS area is too large or too wide to be fully covered by the available mounting surfaces for the specified RSSI at 1 meter value.
Solution
Inspect the output Uncovered_IPS_Area feature class and verify that sufficient wall segments are available near the IPS area. Or consider adjusting the beacon configuration and increasing the RSSI at 1 meter value.
