250130: The IPS positioning points area exceeds the extent of the specified IPS area features on levels with the following level ids: <value>.
The IPS positioning points area cover a larger area than the defined IPS area.
Solution
Ensure that the IPS positioning points area is contained within the specified IPS_Area features area. If the IPS positioning dataset was generated using the survey-based method, the provided IPS_Area is internally buffered by 1.5 meters (4.9 feet) before validation against the IPS positioning points.
