260002: Model Type is set to ZeroShotClassifier. Set the desired candidate labels.
The table was not created because the ZeroShotClassifier model was used and no candidate labels passed. Candidate labels are the set of possible class labels that each sequence will be classified into. A candidate label can be a single label, a string of comma-separated labels, or a list of labels.
Solution
Set the candidate labels in the Model Arguments parameter. For example, to classify the text into positive and negative classes, use a name of candidate_labels and value of positive,negative.
