260062: The selected Text Field or Label Field parameter is invalid.
The tool attempted to use the Text Field or Label Field parameter value for text transformation and failed. The failure may be due to one of the following:
The selected Text Field value contains text that could not be transformed, such as empty strings or numerical values.
The Label Field value does not contain the labels to be used for transformation or has null values such as empty strings.
An unequal number of classes exist in the train-validation set.
Solution
Do any or all of the following:
Specify an appropriate in the Text Field parameter value from the input table to be transformed.
Specify a column with labels from the input table for the Label Field parameter.
Increase the Validation Percentage parameter value.
