260382: The Analysis Variable is required when using a third-party model. Make sure the correct value is selected from the drop down.
When using a third-party model for time series forecasting, the Analysis Variable parameter value must be specified in the form of a specific data attribute or field. This variable is necessary for defining the data that the model will analyze and forecast.
Solution
Ensure that the correct value is specified.
