260499: No target features found within the processing extent. The output will be empty.
No features from the Target Features parameter value fall within the specified processing extent, so there is no data to process and the output will be empty.
Solution
Ensure that the processing extent overlaps with the Target Features parameter value. Adjust the extent settings or verify that the correct target layer is provided so features fall within the analysis area.
