270008: The number of records reselected <value> does not match the number of records in the file <value>.
The number of records reselected does not match the number of records in the .json file.
Solution
A definition query or selection on an input may result in fewer records than expected by the SQL query. Clear the selection or uncheck the Use selected records parameter to run on the entire dataset.
Alternatively, if the dataset has been edited or records have been deleted since the .json file was created, some IDs listed in the file may no longer exist in the data. The tool will only select records that are currently in the dataset, and no additional steps need to be taken.
