Make Masks From Rules (Topographic Production Tools)
Summary
Creates polygon masks for features based on color rules.
A product file installer is available for ArcGIS Topographic Mapping. The product files contain predefined XML masking rule files that can be used for cartographic production.
Learn more about product files
Usage
  • This tool will process the rule file and for each rule, identify the intersection of symbolized features based on the colors or symbol parts defined in the rule. It will create a masking polygon at the intersection of the symbolized features. The rule file allows for storing masks in multiple feature classes.
  • When using Spot colors, the following text or feature items must match the rule color:
    • Spot description—Standard map products that adhere to a specification use a 5-digit number. For example, black is 58600.
    • Spot values—A tint value and opacity value separated by a comma, for example, 42, 100.
    • CMYK alternates—The matching CMYK value for a spot color. For example, 58600 is matched to 0,0,0,100 in ArcGIS Pro.
  • The color rules are defined in an .xml file. A rule specifies that symbolized features of a particular color be masked by a source feature that has a particular color.
    The following example rule is based on a map specification in which a mask will be created for any location where the outline of a black symbol (color of 0,0,0,100 CMYK) intersects a piece of black annotation.
    <RuleGroup>
            <!-- CMYK Feature Masks -->
            <Mask Size=".1" Units="Points" Type="Box"/>
            <Source SymbolPart="Text_Only" LayerType="AnnotationLayer"/>
            <Target SymbolPart="Outline_Only" LayerType="FeatureLayer"/>
            <TargetExclusions></TargetExclusions>
            <Rules>
                <Rule Name="FeatureMasks_Black_CMYK_1pt">
                    <MaskFeatureClass>FeatureMasks_Black_CMYK_1pt</MaskFeatureClass>
                    <Source Color="0,0,0,100"/>
                    <Targets>
                        <Target Color="0,0,0,100"/>
                    </Targets>
                </Rule>
            </Rules>
    </RuleGroup>
  • The size of the mask that will be generated depends on the map scale. Ensure that you set an appropriate reference scale on the map or zoomed the map to the desired scale. The scale should match the scale of the output product to which the mask will be applied.
  • When creating masks for annotation layers, create the annotation at the same scale as the output product.
  • The projection of the map should match the projection of the output product to which the masks will be applied. If the mask features will be stored in an existing feature dataset, the coordinate system of the feature dataset should match the projection of the output product.
  • Ensure that the output feature dataset does not contain any data that the Input Map parameter value is using as a source, such as map layer data.
  • The MaskFeatureClass tag in the mask .xml file determines the name of the mask feature class that will be created. If a feature class with the same name already exists in the database specified for the output feature dataset, the feature class will be deleted and re-created. Masks will not be appended to existing feature classes.
  • Masks will be created for all layers in the specified map that have symbol parts that use the specified colors. To prevent masks from being created for a specific layer, add the name of the layer to the Target Exclusions tag.
Parameters
Label Explanation Data type
Input Map
The map containing symbolized features.
Map
Rule File
The .xml file containing rules that define how features will be masked based on colors and symbol parts.
File
Output Feature Dataset
The output feature dataset. The tool will create a feature dataset containing polygon feature classes that will be used for masking. The spatial reference for the feature dataset will be taken from the map for which masks will be generated.
Feature Dataset
Environments
Extent
Licensing information
  • Basic: No
  • Standard: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
  • Advanced: Requires Topographic Mapping or Aviation Airports or Aviation Charting or Maritime or Bathymetry
