Disable Network Topology (Trace Network Tools)
Summary
Disables the network topology for an existing trace network.
Usage
  • The topology must be disabled when adding or assigning network attributes.
  • For enhanced performance, it is recommended that you disable the topology before loading data.
    Learn more about how to disable the network topology
  • When working with an enterprise geodatabase, the requirements are as follows:
    • The input trace network must be from a database connection established as the database trace network owner.
    • License:
      Organization members must be assigned a license for the ArcGIS Advanced Editing user type extension to use this tool in an enterprise deployment.
Parameters
Label Explanation Data type
Input Trace Network
The trace network where the network topology will be disabled.
Trace Network; Trace Network Layer
Derived output
Updated Trace Network
The updated trace network.
Trace Network
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
