Orientation data coordinate system conventions
The exterior orientation conventions of images that are supported as input to Reality Studio, the supported orientation of the image coordinate system with respect to its exterior orientation, and an overview of the compatibility of data generated from common postprocessing software are described below.
Camera position coordinates (x,y,z)
Camera position coordinates define the position of the camera center at the instance an image is captured. Camera position coordinates can be imported from the images' metadata, a text navigation file containing GNSS\INS data, Inpho project file (.prj), HxMap orientation files (.gori), or SURE orientation files (.ori). The units of the camera positions are defined by the coordinate system specified at the time of import.
Camera rotation angles
Camera rotation angles define the rotation of the camera center at the instance an image is captured. Supported camera rotation angles are described in the following sections.
Rotation angles - omega, phi, kappa
Camera rotation angles define the orientation of the camera at the instance an image is captured. The rotation can be imported from a text navigation file containing GNSS\INS data or from a well-known orientation file format. When orientation data is imported using a text file, the supported rotation convention is as follows:
  • Omega \((\omega)\), phi \((\phi)\), and kappa \((\kappa)\) are counterclockwise (mathematically positive) rotation angles in the specified angular unit used to transform a point from the camera coordinate system to a world coordinate system (cam-to-world).
  • The rotation transformation matrix can follow either the x,y,z sequence (0) or the y,x,z sequence (1), which are defined as follows:
    • \(R_{\text{cam\_2\_world}} = R_x(\omega)\,R_y(\phi)\,R_z(\kappa) \;\;(0)\)
    • \(R_{\text{cam\_2\_world}} = R_y(\phi)\,R_x(\omega)\,R_z(\kappa) \;\;(1)\)
  • The rotations are applied on the rotated axes.
Rotation angles - roll, pitch, yaw
The roll, pitch, yaw rotation angles can be imported from a text navigation file containing GNSS\INS data or from the images' metadata. They define the rotation of the body (aircraft or drone) with respect to its navigation coordinate system.
The rotation angles with respect to the navigation coordinate system are defined in the following way:
  • Roll—Rotation around the front-to-back axis
  • Pitch—Rotation around the side-to-side axis
  • Yaw—Rotation around the vertical axis
Image coordinate system and exterior orientation
The image coordinate system of each view must coincide with its exterior orientation. The default convention of most postprocessing software defines the x-axis of exterior orientations in flight direction. If the x-axis of the camera is not aligned with the flight direction, you need to specify the necessary rotation of the image coordinate system so that it meets the correct input convention. To do this, modify the axis orientation value in the Image Coordinate System section of the Capture Session pane.
If you calibrated the camera beforehand, enter the determined distortion parameters in the Distortion section of the Capture Session pane.
You can choose between the following camera distortion models:
  • Brown's model—Described by three radial parameters (K1,K2,K3) and two tangential parameters (P1,P2).
  • Radial distortion table—Described by distortion values according to radial distance from camera principal point.
Reality Studio supports re-estimating the Brown distortion model during alignment, if you defined the Brown model or no distortion model during capture session creation.
Compatibility with postprocessing software
When exporting navigation data from postprocessing software, consider the following:
  • The direction of the transformation (world-to-cam or cam-to-world)
  • The order of rotations applied (x,y,z; y,x,z; z,y,x; and so on)
Reality Studio supports a cam-to-world transformation and the x,y,z rotation sequence. If you have existing data with different conventions, it may be possible to import it with minor modifications. For example, if the transformation direction is world-to-cam and the order of rotation is z,y,x, negating the sign of all angles (multiplying each angle by –1) allows you to load the data into Reality Studio.
The subsections below describe findings and recommendations based on initial testing to help you use navigation data from some postprocessing software.
AEROoffice (IGI)
Exterior orientation that is exported using the MATCH-AT-AWE format type is supported by Reality Studio.
POSPac (Trimble Applanix)
You can export this data using the following conventions:
  • Transformation—Cam-to-world
  • Rotation order—x,y,z
HxMap (Hexagon)
The exterior orientation exported from HxMap is supported by Reality Studio.
Export data from multicamera systems as .csv files only. HxMap orientation files (.gori) for multicamera systems are not supported.
When using .gori files, the principal point offset must be zero.
Ultramap (Vexcel)
The rotation order of the exterior orientation exported from Ultramap is supported by Reality Studio. Select the Phi-Omega-Kappa sequence from the supported Rotation Definition options.
