Copy a geometry
After you import, create, or edit a geometry in ArcGIS Reality Studio, a copy of the geometry is saved as a shapefile (.shp) and is stored on disk. The original geometries remain and are no longer used.
You can copy the shapefiles from a ArcGIS Reality Studio project to share the geometries with colleagues or between projects.
To copy a geometry shapefile, complete the following steps:
  1. On the Project Tree pane, right-click the geometry, and click Open File Location .
    The folder containing the geometry shapefiles (.shp) opens in File Explorer.
  2. Select and copy all the files that have the geometry name as a prefix except the LOCK files.
    There should be eight shapefile components and four LOCK files.
