Export an alignment
You can export an alignment at any time after it is created. An alignment can be exported as frames and cameras tables or as an Inpho project.
Export an alignment as frames and cameras tables
To export an alignment to a frames table and cameras table format, complete the following steps:
  1. In the Project Tree pane, click the alignment to export.
  2. On the Alignment tab, click Export , and click Frames and Cameras Tables.
    The Export alignment as Frames and Cameras Tables dialog box appears.
  3. Browse to a valid location and provide a name for the alignment.
  4. Click Save.
The alignment is exported as a .csv file.
Export an alignment as an Inpho project
An Inpho project file (.prj) includes the exterior orientation information of each image and the parameters of each camera. If the alignment contains control points and image measurements, they are exported as well.
To export an alignment as a .prj file, complete the following steps:
  2. On the Alignment tab, click Export , and click Inpho Project.
    The Export alignment as Inpho Project dialog box appears.
  4. Click Save.
The alignment is exported as a .prj file.
